what cable do I need
Go to solution Solved by Tagiau,
pics of drive below
Those are sata.
usually 2.5 inch drives need a sata cable and a sata power cable. tough since you said this isn't a normal one i really woudnt know :(
https://linustechtips.com/topic/531932-what-cable-do-i-need/#findComment-7059703
I have a 2.5 inch hard drive that would normally go in something like a laptop.  Can anyone link me to a cable that I would need to plug this thing into my computer?  It's not a normal SATA cable but idk what I exactly need.
only 1.8 inch drives use a different connector, and slim dvd drives
https://linustechtips.com/topic/531932-what-cable-do-i-need/#findComment-7059829
If its just temporary like you want to get something of the disk or write something to it these are really handy:
http://www.amazon.com/iDsonix-U3102-Drive-Docking-Station/dp/B00FDLCTQO/ref=sr_1_3?s=pc&ie=UTF8&qid=1453416523&sr=1-3&keywords=usb+HDD+reader
https://linustechtips.com/topic/531932-what-cable-do-i-need/#findComment-7059837
~snip~
Hey there :)
You would need the regular SATA cable and SATA power cable that you would use on a normal 3.5" drive. There are no differences between 2.5" drives and 3.5" drives in terms of compatibility unless there are some specifics like a soldered USB port or the drive being SAS, PATA or something else. :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/531932-what-cable-do-i-need/#findComment-7065784
