problem with evga precisionx
Go to solution Solved by 0x1e,
hi
i was trying to overclock my 970 when i went over the limit a bit and then the computer crashed. i rebooted and tried to set to defaults but the computer crashes whenever i open precisionx. how do i reset it? can i just delete presisionx? i have it through steam.
thanks in advance!
Uninstall and reinstall.
Next time don't tick "apply overclock on windows start up, or program start up". You should only do that once you're completely sure it's 100% stable.
hi
thanks in advance!
https://linustechtips.com/topic/531829-problem-with-evga-precisionx/
You shouldn't have any problems deleting it. My guess would be that it's crashing because the second you open it, it is setting the overclock which then crashes you. Might want to use something like Afterburner instead, and make sure everything is set back to default before you try again.
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
hi
thanks in advance!
It's not a race to the bottom.
You should be able to just delete the config file, which should be in your %APPDATA% folder
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
