So I'm planning on cleaning out the old thermal paste from my GTX 780 (reaches 80c+ under load, should be getting 70-75) and I want to make sure I do it right. I have a few questions just to make sure I don't screw it up, though it shouldn't be too difficult.
1. Should I use cotton swabs or a microfiber cloth (lint-free) with isopropyl alcohol to clean off the old thermal paste?
2. Will any of these Thermal Compounds do? Arctic Silver 5, Noctua NT-H1 & Deepcool THP-Z9.
3. What method should I use to apply it and how much? The Pea, Line, Spread or X/Cross method? From what I read, the X method ensures that you cover the entire GPU. There are even people out there in big forums suggesting the credit card spread method, since a GPU requires the entire thing to be covered rather than a circle. I'm not sure how big GK110 is for reference, so I'm undecided.
https://linustechtips.com/topic/531455-gpu-thermal-compound/
cotton swabs to get it off, then rub down with microfiber
any of them will work
line usually works just fine, but id have to do more research
https://linustechtips.com/topic/531455-gpu-thermal-compound/#findComment-7050224
Just joined the forum? Read this:
A Quick Guide To Get Started
Need Help Doing Something? Read this:
Guides & Tutorials Catalog
Need a New SSD? Read this:
Droidbot's SATA3 SSD Tier List
Need a New PSU? Read this:
PSU Tier List
In the mood for some memes? Look at these:
Linus Memes
Want to know my PC Specs and Peripherals?
CPU - Intel Xeon E5 2609 v3     Motherboard - ASRock X99 Extreme3      RAM - 16gb HyperX Fury DDR4      GPU - EVGA Nvidia GeForce GTX 770 SC
Case - Inwin 103       Storage - HyperX Savage 240gb SSD      PSU - 550W Enermax NAXN      Display(s) - 2x Lenovo L27i-28, Dell 24"      Cooling - Corsair H100i Platinum     Keyboard - Corsair K95 Platinum MX Speed      Mouse - Logitech G900      Sound - Audio Technica ATH-M50x     Operating System - Windows 10 Pro
Join the LTT F@H Team!
You can help scientists studying Alzheimer's, Huntington's, and many cancers by simply running a piece of software on your computer.
Start now: Folding@Home Install Guide and Links
https://linustechtips.com/topic/531455-gpu-thermal-compound/#findComment-7050239
Arctic Silver 5 sucks and I know that from personal experience. Takes a billions years to cure. Use this;
http://www.amazon.com/dp/B004ULZITS/?tag=pcpapi-20
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/531455-gpu-thermal-compound/#findComment-7050429
