Hi I am looking for a case for my upcoming broadwell-e build(in the next few months). I well be flexing(because that's a thing right?) with as many  6tb hard drives as I can 8, so that this PC can also double as a plex server. What cases do you recommend that have tones of hard drive space, able to be neat and clean, and has decent airflow for 2 GPUs? I am not sure if I will be water cooling the GPUs as of right now. I don't want a caselabs case, although bad ass; they are too big for me.
Here is where I would keep my frolics if I had any.
https://linustechtips.com/topic/531392-case-for-8-hdds/
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/531392-case-for-8-hdds/#findComment-7049394
That only has 2 drive bays included with it. You'll need to buy more from Phanteks if he gets that case.
https://linustechtips.com/topic/531392-case-for-8-hdds/#findComment-7049426
https://pcpartpicker.com/parts/case/#J=8,20&qq=1&sort=a8&page=1
You can use pcpartpicker to see what cases have 8 HDD bays by using the sorting
on the side.  I would go for the trusty Fractal Design Define R5 because it has pretty
good water cooling capabilities in my opinion, I'm sure theres a better case but with
minimal research, I'd recommend that
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/531392-case-for-8-hdds/#findComment-7049442
Node 804 does all that.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/531392-case-for-8-hdds/#findComment-7049513
Coolermaster Cosmo SE.
http://www.coolermaster.com/case/full-tower-cosmos-series/cosmos-se/
It has 8 hdd bay inside.
Go check it out.
I never knew they made a smaller cosmos, and in recent years too.
https://linustechtips.com/topic/531392-case-for-8-hdds/#findComment-7049930
I also vote Node 804. Usually when you use that many drive at once, they block airflow. A split chamber case is the best option. It's mATX though.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/531392-case-for-8-hdds/#findComment-7050651
