My Build Plan: White Haven
Go to solution Solved by Memories4K,
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($183.88 @ OutletPC)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  ($89.99 @ Micro Center)
Video Card: MSI Radeon R9 380 4GB Video Card  ($219.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Monitor: Asus VX238H-W 23.0" Monitor  ($124.98 @ Newegg)
Speakers: Gear Head SP2000URED 3W 2ch Speakers  ($18.12 @ Amazon)
Other: Windows 10 from r/Microsftwareswap (Buy from s5ean) ($30.00)
Total: $822.52
Generated by PCPartPicker 2016-01-20 18:36 EST-0500
Note: This is including the $30 Windows 10 key
Also, i color-schemed your internal build.
So White Haven outside, Red-and-Black beast inside.
I see you fam, i see you.
My first build that I'm planning on doing in the future. I call it the White Haven:
PCPartPicker part list: http://pcpartpicker.com/p/GbkQXL
Price breakdown by merchant: http://pcpartpicker.com/p/GbkQXL/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: MSI H97M-G43 Micro ATX LGA1150 Motherboard  ($86.65 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  ($41.99 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($65.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card  ($209.99 @ NCIX US)
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case  ($37.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($25.59 @ SuperBiiz)
Total: $824.06
My first build made for video editing and gaming. Reason why i didn't put an OS here is because you can get $30 OS keys here:https://www.reddit.com/r/microsoftsoftwareswap/
Edit: For people who saw this build before i edited this, stupid website didn't save changes
https://linustechtips.com/topic/531271-my-build-plan-white-haven/
You should get an XFX or Sapphire 380 so the Red doesn't clash
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
For editing 16gb of ram is highly recommend. What will you use for storage? Will you game more or edit more(priority)?
And White Haven? The internal color scheme is all over the place.
I noticed some of my changes did not save, i had a segate 2tb beforehand. I'm going to be gaming more than editing.
Total: $822.52
"If you ain't first, you're last"
Total: $822.52
THIS
Total: $822.52
Oh wow, this is awesome! I wasn't sure whether or not to get speakers because the monitor comes with them built in
Nah trust me, you want speakers. I kept all your peripherals the same because i wasn't sure if you were deadset on them or not.(Although i was tempted on chaning the panel, but of course the build's called White Haven)
If you're not going with anything high-end i say get some Amazon Basic speakers, they work well and would be cheaper than your current picked option.
Ok, thanks for your help. I really appreciate it
