Amazon Basic Tripod
Solved by DebatED Nothing,
-snip-
I can't see anything particularly wrong with that bipod, so long as your camera isn't too heavy (supports up to 3kg) and will mount properly. RE the gopro mounting question, it depends, do you need to put a gopro on it? If so then yes, you should probably buy one that can mount a gopro, but if not then don't bother.
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
3
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Posted in Servers, NAS, and Home Lab3 -
Sveeno ·
Posted in LTT Releases8
play_circle_filled
Latest From ShortCircuit:
