Serial number help
Go to solution Solved by SawmanTheNerd,
Check the box or the underside of the cooler.
Already checked it might be the sticker on the rad that I didn't see lol found it haha!
I think you misunderstood I'm asking where not what...
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/531099-serial-number-help/#findComment-7045608
Did you look on the box...?
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/531099-serial-number-help/#findComment-7045617
