Do cases automatically come with fans for its ventilation and/or you have to buy fans separately for its ventilation ?
A case's spec page will state whether it comes with fans at stock, and where they are installed at stock.
You can generally replace most fans pretty easily as you wish, to be able to use better ones, or ones of different colors, or with LED lighting, etc.
Sig under construction.
https://linustechtips.com/topic/530846-case-ventilation/#findComment-7042614
Normally cases do comes with fans and the number of fans depends on the case you buy, sometimes u have to add more fans and sometimes u don't
https://linustechtips.com/topic/530846-case-ventilation/#findComment-7044348
