I heard that Novus works pretty well
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/530061-side-panel-scratches/#findComment-7032471
acrylic or plastic
Novus makes a really nice polishing kit for acrylics, but they will always come back overtime with cleaning from fine scratches, the only way to really avoid or get rid of them is getting something like glass which has a much higher scratch resistance.
http://www.amazon.com/NOVUS-7100-Plastic-Polish-Kit/dp/B002UCYRZU
https://linustechtips.com/topic/530061-side-panel-scratches/#findComment-7032667
