Here's the Image easier to show than explain..
I am just browsing my social media and that thing popped-up.
I've also tried to open crimson and check updates, and same thing popped-up
CPU: Ryzen 7 5800X | MOBO: Gigabyte B550 Vision D | RAM: Crucial Ballistix RGB 32GB 3600MHz | GPU: Gigabyte RTX 3070 Vision D | PSU: Seasonic Focus+ Gold 750W
https://linustechtips.com/topic/529893-crimson-issues/
Other systems I've built:
https://linustechtips.com/topic/529893-crimson-issues/#findComment-7030416
Don't see a image
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/529893-crimson-issues/#findComment-7030429
Same thing happenend to me a few minutes ago
I see then the issue is with the software most likely?
Yes it is.
Don't see a image
Fixed it sorry.
https://linustechtips.com/topic/529893-crimson-issues/#findComment-7030458
