hi,
i am building my first pc and found almost all parts but I am not sure of what GPU and monitor could I use. I don't actually need to get perfect fps or 4k videogames and it is primarily for work and not so demanding games. I was also planning on making it a two monitor build keeping it on a low budget, what so you reccomend?
my build:
http://pcpartpicker.com/p/vdQgvK
I would really appreciate some help.
https://linustechtips.com/topic/529056-help-on-finding-a-gpu/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  (Purchased For $0.00)
Motherboard: Asus M5A97 R2.0 ATX AM3+ Motherboard  (Purchased For $0.00)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($169.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  (Purchased For $0.00)
Total: $378.84
Generated by PCPartPicker 2016-01-17 11:20 EST-0500
Better PSU and much, much better GPU.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/529056-help-on-finding-a-gpu/#findComment-7019951
I would push to the 900 series from Nvidia and just cut into a cheap GTX 960 if you can, have used 960's in the past when building and they have done VERY well, if you cant cut a 960 then drop to a 950, i don't know on the AMD side but i would assume the R9 380 is its equivalent, haven't worked much with AMD kit so i wouldn't know too much.
I can't stop spending money my stupid home lab, help.
https://linustechtips.com/topic/529056-help-on-finding-a-gpu/#findComment-7019972
What is your max budget? And what games specifically do you plan on playing with it?
not demanding games, like Rocket league at pretty good fps with good image quality. I would like to save as much as I can so I can buy double or triple monitor to make work easier.
Thanks for the help.
https://linustechtips.com/topic/529056-help-on-finding-a-gpu/#findComment-7047455
That case is overpriced. Get an NZXT S340 and get a gtx 950.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/529056-help-on-finding-a-gpu/#findComment-7047498
SLI a pair of 980Ti's then just get 2 Gsync monitors and you should be ok. But don't forget your oculus rift.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
https://linustechtips.com/topic/529056-help-on-finding-a-gpu/#findComment-7052450
