I am planing to overclock my i5-3570k to 4.5 or even a little higher and was wondering which of these coolers would have better performance in cooling. The Cooler Master Hyper 212 evo or the Corsair H50 Liquid Cooler. Would the 212 evo be sufficient enough even if I am overclocking, or should I exceed my budget to get a higher performing liquid cooler. If anyone knows how high I could push the 3570k before I would need a better cooling solution than the 212 evo that would be great. Thanks for any responses!
Hyper 212 Evo: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Corsair H50: http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010&Tpk=corssair%20h50
https://linustechtips.com/topic/52876-overclocked-cpu-cooler-question/
with a 212 evo you can probably hit 4.2ghz without problem but i dont think you can get much higher without an h80 or h100 kind of cooling.. again it depends on your chip as well as ambient temps i could be wrong and you may be able to ht 4.5ghz off a 212 though i have yet to see it happen
for liquid coolers i would not go under an h80i. For air coolers the Evo performs very well. If you can move your budget up a bit I would go with the Noctua U12S if you can stand the fan color or the Xigmatek Dark Knight.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
It depends how you place in the sillicon lottery. You can't say you want to overclock to this clockspeed. It depends how much you have to increase the voltage.
P.S single fan AIO coolers is stupid just get the best air cooler you can get for the same price
I would take the Hyper evo i think it will do better then a single slim rad all in one.
However if u will be able to hit 4,5 hmmm questionable u would need a premo binned i5 i think.
Go for a H100i or something simalar and it will be easy
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
I have a 3570k with a sabertooth board and I'm using a 212 evo right now. The automatic overclocking on board got it to 4.2 and I was able to get it to 4.4 without any trouble.
Edit: my 212 evo is in push/pull with corsair sp120 quiet editions.
The Evo is cheaper, better, and can reach up to 4.5-4.6 ghz depending on your chip and case airflow.
