How many fans can the Phantek Enthoo Evolv ATX hold?
Solved by DrtyDiesel,
I have the evolv atx, it comes with two 140mm fans in front, or you can swap those out for up to (3) 120mm fans. The top will hold (3) 120mm fans or (2) 140mm fans. The rear comes with a 140mm fan and can also hold a 120mm. The rear also has rails where you can slide the fan up and down.
Straight from their website.
Featured Topics
Dan1718 ·
Posted in Troubleshooting1 -
Zexer2020 ·
martixy ·
Posted in Phones and Tablets1 -
CentreMetre ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Graphics Cards9 -
6
10
