Hey everyone.  I've been looking for a decent laptop to play Starcraft 2 on, and I found these:
1)  http://www.futureshop.ca/en-CA/product/samsung-samsung-ativ-book-4-15-6-laptop-black-intel-core-i5-3230m-1tb-hdd-8gb-ram-windows-8-np470r5e-x01ca/10257710.aspx?path=88067c8e9c6934f36e464173303d5608en02&SearchPageIndex=1
2)  http://www.futureshop.ca/en-CA/product/hewlett-packard-hp-envy-15-6-laptop-silver-amd-elite-quad-core-a10-5750m-1tb-hdd-8gb-ram-windows-8-15-j084ca/10257099.aspx?path=54f26f3537d46bfc754fbd1ed6a35d15en02
The first laptop has a Intel Core i5 3230M processor, whereas the second laptop has a AMD Elite Quad-Core A10-5750M processor.  Both have the same graphics card (AMD Radeon HD 8750M).
So my question is, which of these 2 processors are better to play Starcraft 2 smoothly without any lag?  And overall, which laptop should I get?
Thanks.
https://linustechtips.com/topic/52836-starcraft-2-laptop-help/
Thanks.
AMD CPUs don't like SC2 all that much [don't get me wrong here, me gusta AMD] so I'd go with the Intel version. And Samsung > HP anyways ;)
And SC2 is very very CPU intensive, so you'll be better off with the i5 over the APU. ^^
Frost upon these cigarettes.... lipstick on the window pane...
https://linustechtips.com/topic/52836-starcraft-2-laptop-help/#findComment-708191
sc2 is not cput intesnvie at all. fals einformation. it uses just as much cpu usage per core as crysis 3 crysis 2. or 3 times less then 64p game in BF3 ULTRA
lol you could play 1080p ULTRA 1080p at that price... anyway
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/52836-starcraft-2-laptop-help/#findComment-709469
Wrong.
I5 is better then the APU for cpu tasks. the APU has better igpu.
Needless information as the laptops have a dedicated GPU.
Ea still better then blizzard
Drugs are bad for you.
https://linustechtips.com/topic/52836-starcraft-2-laptop-help/#findComment-711521
Wrong.
true.
Needless information as the laptops have a dedicated GPU. not needless for someone who doesnt know.
Very constructive, but I dont live in the past.
https://linustechtips.com/topic/52836-starcraft-2-laptop-help/#findComment-714591
