So I was trying to remove some thermal paste that was on the sides of the GPU die and I ended up smearing most of it in the transistors and I've been doing some reading on how to remove it. Someone said you can use a tooth brush... Can I do this?
Processor i5 4440 Graphics Card GTX 980ti Motherboard MSI B85M-G43 Memory 8GB Storage 1TB HDD Power Supply XFX TS 750W Case Fractal Design Core 1300
https://linustechtips.com/topic/527696-thermal-paste-question/
Yea sure, just make sure it's a soft bristled brush and dip it isopropyl alcohol before you scrub gently.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003341
• Take a disposable bowl.
• Take 90% or higher isopropyl alcohol.
• Pour about one cup of alcohol into the bowl.
• Place GPU side down into bowl.
• Let soak for about 5 - 10 minutes.
• Wait.
• Take a toothbrush, preferably a soft bristled one and dip that into the alcohol also.
• Softly and I mean softly brush till all the thermal grease is removed.
• Let GPU dry on either a lintless towel or a paper towel till the alcohol is evaporated.
• Throw the bowl away. In a recycling bin. Good for the planet.
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003345
why did you do it in the first place?  :rolleyes:
just wipe it off with some qtips, id be gentle if i would use a tooth brush tho lol
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003346
• Wait.
Dipping the whole graphics card in isopropyl alcohol is probably a bit overkill for cleaning the little tiny capacitors next to the GPU die.
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003355
Couldn't think of another way ATM  :P I'm stupid that way
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003360
A brush for teeth is a fine solution, but thou must make sure it is soft, so not to damage the board!
It looks as if the peasants have risen up, and found swords!
But their sword's look a little short, if you know what I mean!
Good! The squires need training anyway!
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003374
I always use a q-tip and isopropyl 90% it just makes me feel safer.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003398
Concerning temperatures led me to believe that was the problem.
https://linustechtips.com/topic/527696-thermal-paste-question/#findComment-7003631
