First PC build
Solved by HKZeroFive,
The i5 will be better at gaming with its more powerful individual cores, paired with the R9 380. Gave you a better PSU:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($174.89 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($71.88 @ OutletPC)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card ($164.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case ($64.99 @ Directron)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($50.99 @ SuperBiiz)
Total: $607.71
Generated by PCPartPicker 2016-01-15 02:31 EST-0500
