Problem with OCing FX-6300
Go to solution Solved by MrSnakes,
no dice, still unsolved, might endup buying the 970A-UD3P Gigabyte motherboard
Hi guys,
I have a huge problem when overclocking my FX-6300 AMD CPU. My speed is 4500MHz, with temps around 54C and 49C under load (using a prime95 stress test). However occasionally it will drop to 2999.84MHz from 4499.76MHz. The CPU temp doesn't even change when this happens it just drops to 3000MHz every few seconds for no apparent reason.
EDIT: Also happens when on stock settings like 3500MHz.
4500MHz
3000MHz
Yes AMD Cool and Quiet is off.
Here are my specs:
MB: ASUS M5A78L-M/USB3
CPU: FX-6300
CPU-Fan: Cooler Master Hyper 212 EVO
GPU: Gigabyte R9 280
PSU: Corsair CX600M
RAM: 4x2GB (8GB) not sure on specific brand taken from prebuild PC's
Case: NZXT S340
Temps:
You must be the change you want to see in the world.
- Mahatma Gandhi
https://linustechtips.com/topic/527193-problem-with-ocing-fx-6300/
Hi guys,
Here are my specs:
CPU: FX-6300
PSU: Corsair CX600M
Case: NZXT S340
disable the energy saving feature  on your board ? ( vdroop , but don't know if it has the same name on amd )
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
I thought cool and quiet was the energy saving feature.
- Mahatma Gandhi
idk , never used any fx cpu before
No VRM heatsink... try putting a fan on your VRMs to see if it solves the problem, they could be overheating and throttling your cpu.
doesnt seem to be working. though I wouldn't be surprised if it was too hot anyway, what motherboard can you recommend for overclocking an FX-6300? and maybe an FX-8350 down the line.
- Mahatma Gandhi
One thing to note though is that the problem happens as soon as I press the test button.
wouldn't it take time for the VRM's to heat in the first place?
Also is it to do with TDP.
- Mahatma Gandhi
Yeah, if it happens right away, it might not be heat but some power limit integrated into the board, I haven't looked into AMD motherboards in a long time, wouldn't know what to recommend you, you could always check if you're on the most recent bios version.
rofl it might be this I've never updated my BIOS xD.
Will do that now.
- Mahatma Gandhi
