I realize i just made a similair post last night, but with the info i gained from that, does anybody know anything about razer maybe releasing a razer blade stealth with a better cpu? maybe a quad core or a quad core with hyper threading?  or is there an option they have that already exists that supports the razer core?
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/
No, intel doesn't have such option that is low powered enough.
At least for this generation.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/#findComment-6996868
If they continue with using U class cpus, I doubt they can have anything better.
The design is based off the current cpu, so putting a faster, but higher TDP chip in there will need some redesigns...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/#findComment-6996874
This is as good as it gets for the Blade Stealth. The CPU inside it is weaker than a i3 4170.
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/#findComment-6996905
Damn!  They were sooo close, just a litter more cpu horsepower and the blade stealth with a razer core would be perfect for a lot of people
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/#findComment-6996981
Still bulky and hard to transport. Gamers who want to play on the go wouldn't have been tempted by it. I know I'm not.
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/#findComment-6997003
It's not gaming in the go that would be enticing, it's the idea of having a powerful (desktop) gaming rig with a mouse and keyboard and a monitor, then a laptop for on the go
https://linustechtips.com/topic/527191-razer-blade-stealth-cpu/#findComment-6997416
