So I built my computer yesterday, and I built it out of the case, and so I then decided to at least start looking in the bios, I installed everything and ran power to it, I then short the power pins and then the fans start up, and a few LED's on the system light up, but it wont output anything to the display that I have connected to my graphics card, here is my build
http://pcpartpicker.com/p/KdWzqs
https://linustechtips.com/topic/526905-my-system-wont-post/
Yes. (its actually my TV at the moment through HDMI, and its on the right input, The tv will show that there is a signal from the card, but there is nothing actually on it, it claims "no signal"
I've had a sort of problem like that before. try another tv or borrow someone's monitor, see what happens.
Woo!
https://linustechtips.com/topic/526905-my-system-wont-post/#findComment-6993578
like the graphics card won't output to a TV? because I know its not the TV or the cable because the exact same setup works with the HDMI out of my laptop.
https://linustechtips.com/topic/526905-my-system-wont-post/#findComment-6993608
