Hey Guys,
I am going to be getting a water cooling kit from EK (EK-Kit X240). This is going to be my first water cooler installation (Other than friend AIO) so I am unsure as to where i am going to put everything, if you guys could give me tips or a better loop that'd be great, Thanks!
Sorry for the crappy diagram: https://gyazo.com/25331d62c6aee8c004bc6c436f39b765
​Nothing Screams Professional Other Than Comic Sans
My Build: http://pcpartpicker.com/p/bQVfqs
Dark Theme, GG
https://linustechtips.com/topic/526780-watercooling-help/
Hey Guys,
It's fairly straight forward the diagram you have there is correct, just make sure the pump is below and after the res to ensure to it never runs dry. For installing the blocks they do come with instructions and details on how to do all that.
https://linustechtips.com/topic/526780-watercooling-help/#findComment-6996736
Hey Guys,
Only suggestion I would have is maybe flip the rad so the ports are at the top and try to avoid that long messy run across the GPU if you're not water cooling it.
https://linustechtips.com/topic/526780-watercooling-help/#findComment-6998690
