First Time Build Thoughts
I am sure you know what you are doing unlike me and this is a really nice build, but I was wondering how well that CPU performs with the GPU? Would it get "bottlenecked"? Thanks for the reply!
That CPU probably isn't going to bottleneck you in CS:GO, this has basically the same CPU vs an i5
http://www.technologyx.com/featured/amd-a8-7650k-apu-review-the-little-apu-that-could/5/
an 860+360 will be fine, an i3 + 380 would be better, though going with the 860K+360 would get you a 144hz display
Of course for like 300 bucks you could get an APU build and just use the iGPU, you can find benchmarks at that link as well
PCPartPicker part list: http://pcpartpicker.com/p/VcgPRB
Price breakdown by merchant: http://pcpartpicker.com/p/VcgPRB/by_merchant/
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor ($116.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($67.89 @ OutletPC)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory ($30.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: Gigabyte Radeon R9 380 2GB Video Card ($182.99 @ NCIX US)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($34.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($38.49 @ SuperBiiz)
Total: $522.22
Generated by PCPartPicker 2016-01-12 23:22 EST-0500
