I finally think I've gotten all my parts down. My budget is around $900 CAD (Says more in build cause of tax. I'm pretty set on the parts just wanted to make sure everything is good. (The GPU with by painted to fit the black/blue theme)
PCPartPicker part list: http://ca.pcpartpicker.com/p/VsyFQ7
Price breakdown by merchant: http://ca.pcpartpicker.com/p/VsyFQ7/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($292.72 @ Vuugo)
Motherboard: MSI H97M-G43 Micro ATX LGA1150 Motherboard  ($124.27 @ DirectCanada)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($62.13 @ NCIX)
Video Card: MSI Radeon R9 380 4GB Video Card  ($361.03 @ Vuugo)
Case: Zalman Z11 Plus ATX Mid Tower Case  ($45.06 @ Canada Computers)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($131.08 @ shopRBC)
Total: $1016.29
Generated by PCPartPicker 2016-01-12 20:21 EST-0500
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/526195-final-post/
lol I thought you meant that you weren't going to be on the forum anymore xD
Looks great to me
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/526195-final-post/#findComment-6984090
Total: $1016.29
bring that mother board to a full atx.  the price will be similiar and itll be way easier to work with, especially if you want to add cards
https://linustechtips.com/topic/526195-final-post/#findComment-6984093
Added in a better PSU, SSD and a ATX mobo:
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($87.98 @ NCIX)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($63.05 @ Vuugo)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($311.98 @ Newegg Canada)
Case: Zalman Z11 Plus ATX Mid Tower Case  ($39.88 @ Canada Computers)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($89.98 @ Newegg Canada)
Total: $906.91
Generated by PCPartPicker 2016-01-12 20:24 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/526195-final-post/#findComment-6984100
Micro ATX motherboard in ATX chasis?
Cant find a similar priced one that supports Crossfire
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984104
This is a budget build, and the matx board is cheaper. They still can upgrade later to an ATX for more features if they get that case.
https://linustechtips.com/topic/526195-final-post/#findComment-6984105
Total: $906.91
This ruined all things I wanted from this build. Crossfire, Black and Blue, and MSI parts
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984113
The case will be the first part to be upgraded :P
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984117
XFire isn't necessary when you're on a build like this. It's a budget build and it shouldn't be considered at this price. A single GPU is always going to be better for you.
What's wrong with the parts I gave you? Just because it's not MSI, doesn't mean it's not better. Don't try to spend extra money on something unnecessary.
Mobo is black and blue and it's an ATX.
https://linustechtips.com/topic/526195-final-post/#findComment-6984151
I don't call $900 budget. And the XFire is for later so I can add another GPU if I need to. And Im an MSI fanboy :P. I trust their products and they make the best looking mobos IMO
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984171
you won't be running crossfire at pcie 3.0 x4/x4...you'd need a much better motherboard anyways...and PSU.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/526195-final-post/#findComment-6984216
Don't need XFire/SLI unless you have a 980Ti/Fury X. You're better off upgrading to a 390 instead of XFiring two 380s since a single GPU is always going to be better.
SSD is going to make your life alot easier. Switch out the PSU.
https://linustechtips.com/topic/526195-final-post/#findComment-6984233
Isnt the NEX tier 2 though?
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984250
i would go with what @HKZeroFive suggested above...it,s a great build for the price.
i would let go the SSD for now for a better GPU instead though...i would consider the SSD for a future upgrade especially if you care about gaming performance most.
https://linustechtips.com/topic/526195-final-post/#findComment-6984268
It's a "meh" PSU. There are cheaper options that would be better.
https://linustechtips.com/topic/526195-final-post/#findComment-6984300
If I spent 20 bucks more and got a GS 750 watt would the build be better? And if Xfireing a 380 isnt worth it my next upgrade (after case) will be a Fury or 980 and then XFireing it. Adding Xfire now just doesnt mean I have to later
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984357
GS650 sorry
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984379
Here: http://ca.pcpartpicker.com/part/rosewill-power-supply-capstoneg650
Tier 2 for the record.
https://linustechtips.com/topic/526195-final-post/#findComment-6984388
The SeaSonic PSU is cheaper and will perform reliably. I don't see why you have to get an overkill 750W one for more money.
I highly doubt that'd be soon. Save the money now and worry about that later. Like I said, you gotta spend at least $900 CAD on a GPU before you start to consider XFire/SLI. It's going to present quite a few problems so a single-card solution is always the best bet.
https://linustechtips.com/topic/526195-final-post/#findComment-6984401
Ok, back to the drawing board. I'm not going for that asrock H97 board though. Not worth it IMO
AXIOM
https://linustechtips.com/topic/526195-final-post/#findComment-6984424
