What case?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/526129-best-top-down-cpu-cooler/#findComment-6983170
Probably the Cooler Master GeminII S524 Ver.2
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/526129-best-top-down-cpu-cooler/#findComment-6983186
Would like to keep it under $100 CAD
price is no matter = Cryorig C1
slightly cheaper = Cooler Master Gemin II
even cheaper = Noctua NH-L12
cheaper still = Scythe Big Shuriken 2
cheaper pls = Zalman CNPS2X  didnt see that "replaceable fan" bit..
bang for the buck = Scythe Shuriken Rev.B or EKL Alpenföhn Silvretta or Cryorig C7
all of the above are under 100cad
https://linustechtips.com/topic/526129-best-top-down-cpu-cooler/#findComment-6983257
bang of the buck = Scythe Shuriken Rev.B or EKL Alpenföhn Silvretta
They all perform pretty similarly and I'd suggest just going with the cheapest option especially if the fan is going to be replaced anyway.
As answered here already, the S524 V2 would be one of the better options that comes with a pretty versatile Silencio: http://linustechtips.com/main/topic/526098-cooling-for-corsair-air-240/#entry6983067
https://linustechtips.com/topic/526129-best-top-down-cpu-cooler/#findComment-6983463
