/F: is not accessable Access denied. This is my old Windows Install on another HDD how can I gain permission or mount it as read only?
Right click it and change the NTFS permissions. You should be able to take ownership of all the things also. It will take some time if you do the entire drive at once, and just having the same username on the old windows install doesn't mean your new account inherits the permissions (the SIDs will be completely different).
https://linustechtips.com/topic/526086-f-is-not-accessable/#findComment-6982856
