I have had my computer for over a year now and want to start upgrading it. One of these upgrades is I want to do a small water cool loop for just my CPU. I am currently running a i5 4690k. I figured custom is better than AIO because I get to learn and do it myself, and it is easily expandable when I want to add another radiator and water cool my GTX 780. In addition I am building this in a Define R4. I am thinking of a pump reservoir combo from EK that will go in the 5.25" bay since I will be removing my Disc Drive as I do not use it.
Any help? Tips? Suggestions? Please
https://linustechtips.com/topic/525616-1st-time-water-cooling/
You can go with what's called a "Custom Loop In a Box" EK sells the aforementioned kits.
A good suggestion is the EK-KIT L240 custom loop in a box.
Oh and follow your topics so you see replies like this. Welcome to the LTT Community!
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/525616-1st-time-water-cooling/#findComment-6976495
Welcome to the Forums!
I would recommend to start with a kit for EKWB, it provides a fairly good base to what you will need and can allow for your to expand into a larger loop. If you don't mind doing a bit of modding I would recommend to take out the drive bays and add in a large rad in the front instead to give you lots of opportunity for rad space, the EKWB kits are all tube res based.
https://shop.ekwb.com/kits
https://linustechtips.com/topic/525616-1st-time-water-cooling/#findComment-6976502
Welcome! Good choice, watercooling is pretty bad ass! As for the suggestions a good place to start might be a kit but you can buy 2nd hand radiators and pumps for a fraction of the price of a new stand alone unit. I bought a brand new XSPC dual bay D5 pump/resivior combo for £80 and got loads of free goodies with it, I recently bought a pump for £40 rather than £60, might not sound much but it soon adds up!
If you feel like you would just rather have all the parts and fit them and be happy then the kits from EK will suffice, I recommend a D5 pump and swapping the tubing that comes with the kit for some Primochill Advanced LRT tubing. It should also be known that if you choose nickel plated blocks, don't use silver kill coils or copper sulphate drops in your coolant.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/525616-1st-time-water-cooling/#findComment-6976543
