You don't need 3x 980Tis to run triple 1080.... lol
Also I cannot recommend that headset and those speakers are very overpriced.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
good choice of case.
I have it.
However, add more fans, i have 2 390x cards, and its pretty hot in here
If your're spendiing 5k on stuff, im pretty sure an extra $50 wont make a difference.
also, why 60hz on the monintors?
and what are you playing that requires THREE 980TIS
The sag with the 3 Asus 980ti's.... You're gonna need that dongle Linus played with to fight sag. But that only works with Master case 5.
Current PC: Origin Millennium- i7 5820K @4.0GHz | GTX 980Ti SLI | X99 Deluxe
unless
Nice build but what a waste of money imo, why on earth do u need 3 980ti,also is that that storage really needed for you?
hes like a amateur daily uploader who uploads 2 hour videos every day and needs a way to export them quickly
tell you what, since I saved you from making possibly the biggest PC building mistake you may ever make in your life,
buy me that kraken and ill give you $40
For the audio get a pair of Sennheiser HD558's and a ModMic 4.0 or Blue Snowball
This is what I had for him in his earlier post
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($117.99 @ SuperBiiz)
Motherboard: MSI X99A MPOWER ATX LGA2011-3 Motherboard  ($289.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory  ($199.99 @ Amazon)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($328.95 @ SuperBiiz)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive  ($149.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card (3-Way SLI)  ($669.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($109.99 @ Amazon)
Power Supply: EVGA SuperNOVA 1300 G2 1300W 80+ Gold Certified Fully-Modular ATX Power Supply  ($182.23 @ Mac Mall)
Monitor: Asus ROG SWIFT PG278Q 144Hz 27.0" Monitor  ($669.99 @ SuperBiiz)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($169.99 @ Best Buy)
Mouse: Mionix Castor Wired Optical Mouse  ($69.99 @ Amazon)
Total: $6013.94
Generated by PCPartPicker 2016-01-11 20:46 EST-0500
HE said 3x 980Tis wouldn't get enough FPS in 3x 1440p.
Also for the audio do as I suggested above plus add some Bequiet! Silent Wings 2, 2x 120mm for the bottom and 2x 140mm for the front
Total: $6013.94
now there is a legitimaite use for the 980tis
might as well just get 3 nanos, basicly same power, should be cheaper
and at that 6k price point, might as well go fury
All I see is a waste of money. You're definitely better off with DarkBlade2117's recommendation.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
