A problem I was having was I overclocked the cpu to 4.2ghz but I would run a stress test and it didn't fail... But after launching a game and playing for like 10 minutes it froze so I had to hard restart my pc I hope this isn't just a bad binned cpu... That would make me Sooo mad.
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974053
it be helpful to know what have you tried
what voltages?
how did it fail?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974060
Sounds like it's not getting enough juice, try upping the voltage.
 Almost as cool as my temps
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974064
try 1.35V
before you try... what kind of cooling solution do you have?
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974092
what cooler?
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974098
No error code or nothing
yes that's what you usually get when there's not enough voltage it freezes
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974117
Noctua NH-D14
well yeah try the 1.35V and run Aida64 or Intel XTU or Asus RealBench
monitor temperatures, if it gets to 90*C stop the test it
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974126
Yes but from my understanding Linus got away with 1.3v at a 4.5ghz oc how is that?
he got a better chip
I'm running 5820K at 4.2GHz @ 1.265V and can't get anything more than that
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974143
That makes me a edgey I wonder if I can return my cpu and get a better binned chip
lol )))
you can always try
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974163
Oh and it was 4.0ghz so I don't have any luck with 4.2 ghz basically
explain...
did your PC freeze with 4GHz @ 1.3 V ???
are you sure you set the values correctly in the BIOS?
could I ask for a screenshot of your BIOS and CPU-Z ??
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974223
explain...
Forgot to mention I used a preset and went from that like linus said to. And I can get you a screenshot in a little bit I'm no currently at my pc
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974247
it's fine good motherboard should be fine
https://linustechtips.com/topic/525425-cpu-overclock-help/#findComment-6974447
