Hi!
I have r9 270x and my  temps wenn idl are about 50 C and under load (cs:go, gta v ...) are 70-80 C.
I did research and found that this temps are just fine. But wenn temps come close to 75-80 C randomly freez games or OS and i need rest pc.
Is my gpu about to die or what. I dont think problem is dust cuz wenn this sh** start happening i dusted it off.
All other temps are just fine.
https://linustechtips.com/topic/525397-graphic-card-problem/
wow wow wow
i just went in my radeon setting to find out that my gpu is runing 200 mhz higher them stock and momory clock is 50 higer
hier is my probljem i think
is possible that this happend wenn i upadate to crymson drivers cuz then problems starts
https://linustechtips.com/topic/525397-graphic-card-problem/#findComment-6973708
wow wow wow
Did you OC manually? Is there a chance you mean the boost clock? What version of Crimson?
https://linustechtips.com/topic/525397-graphic-card-problem/#findComment-6973786
