Is there an effective way to better cool the vrms on a gpu? I've got a 780ti directcu ii and the vrms are only cooled by heatsinks. They eventually heat up enough to where it destabilizes my overclocks.
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
https://linustechtips.com/topic/525339-cooling-vrms/
I think you can buy copper heatsinks.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6972824
Ah yeah, I was considering on replacing the heatsinks with better ones. I just have no clue which are good.
I might... Only issue is that it probably would probably be pretty expensive and also its hard to find the block now a days.
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6972884
Asus = bad VRM cooling. Dial back the OC
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6972991
sigh, i guess that's the sad truth....
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6973015
Mine are 75*C at stock (same cooler)
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6973019
Mine hit 84ish at stock....  :huh: I cranked the fan speeds up when i overclock but it creeps up no matter what  :angry:
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6973086
780 Ti uses 300W
280 uses 200W
I guess it's normal with this shitty cooler. Somehow, @Pandalf gets 63*C :D
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6973099
780 Ti uses 300W
280 uses 200W
WUT.... 63???? Dayum
https://linustechtips.com/topic/525339-cooling-vrms/#findComment-6973120
