I am building a rig and do not know what case to pick. My budget for the case is £60 and it needs to support a Micro ATX.
Cooler master N200, there's a nice one.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/525282-need-help-picking-a-case/#findComment-6971979
Some popular ones in that price range:
Enthoo Pro M
NZXT S340
Fractal Design Define S
Xeon E3-1241 @3.9GHz, 1.07V | Asus Z97-E/USB 3.1 | G.Skill Ripjaws X 8GB (2x4GB) DDR3-1600 | MSI RX 480 Gaming X 4GB @1350MHz/2150MHz, 1.09V/.975V | Crucial MX100 256GB | WD Blue 1TB 7200RPM | EVGA 750W G2 80+ Gold | CM Hyper 212+ w/ Noctua F12 | Phanteks Enthoo Pro M | Windows 10 Retail
https://linustechtips.com/topic/525282-need-help-picking-a-case/#findComment-6972411
What are you planning to put inside of it?
https://linustechtips.com/topic/525282-need-help-picking-a-case/#findComment-6984732
