Water Cooling Compatibility
Go to solution Solved by Goat,
You can mount a 120mm radiator at the back but you cannot mount a dual 120mm radiator at the top.
Hi, I was just wondering about my case the Corsair Carbide spec-01, how compatible is it with CPU Water cooling (not whole system cooling) I am not sure whether it is able to fit 1 radiator on the rear or 2 on top, or even none at all!
I have used all fan outputs so a double radiator on top would be nice to fill in all fan holes.
The fan sizes are 120mm.
My MOBO is Z97-D3H if it helps.
Thank you!
https://linustechtips.com/topic/525110-water-cooling-compatibility/
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
