could be damaged wire? Check the connectors on the mobo, could be another reason.
Main PC: Core i5 4670 | MSI Mpower Max z87 | G.Skill Ripjaws 2x4gb | Stock intel cooler | PNY GTX 770 2gb (hoping to upgrade) | Seagate 1tb 7200rpm | Corsair RM850 | Corsair Carbide Air 540 | PCCG custom sleeved black/yellow extensions | Corsair K70 Cherry MX Blue | Corsair M45 |
Phone: LG Nexus 5 | Headphones: Audio Technica ATH-PDG1, Shure SRH440 | Laptop: Asus 303la (i5 model, 1600x900 res) | Motorbikes: 2004 Sherco 290i, 2013 Husqvarna CR125 | Xbox one
https://linustechtips.com/topic/525095-nzxt-phantom-820-led/#findComment-6969866
Its connect to the same sata power cable that the other case's leds are connected to
check to see if its plugged in alright
https://linustechtips.com/topic/525095-nzxt-phantom-820-led/#findComment-6969883
