Hi there everyone. this question is mainly geared towards people who own this case. Does anyone know if a Cooler Master 212 Cooler will fit in this case and not scratch the side panel window? If not I can buy an H60 Liquid Cooler, but rather save the $60 and buy some nice fans instead. Thanks for reading.
Also bonus question:If the Cooler fits, whats the clearance of the Hyper 212 with the fan towards the top of the case?
https://linustechtips.com/topic/524794-nzxt-s340-question/
The cooler is 159mm tall and the max height supported by the case is 161mm.
So it should fit but it'll be tight.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/524794-nzxt-s340-question/#findComment-6966155
Yes, it fits and won't scratch the window.
This much:
https://linustechtips.com/topic/524794-nzxt-s340-question/#findComment-6966341
