Better CPU For Everyday Use
Solved by suchamoneypit,
Look at both these builds that are the same price should i still go with the G3258? The most Multi tasking I do is like two browsers open with 2-3 somewhat graphic intensive sites.
those builds are pretty much identical other than the CPUs, personally I would still go with the Pentium.
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
