Done. Limited range but I did it. You can get it from this store: http://www.cycom.com.my/pricelist.html
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($211.00)
Total: $3038.00
Generated by PCPartPicker 2016-01-09 23:18 EST-0500
Good luck.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/524210-rm3000-plan-build/#findComment-6959610
Total: $3038.00
Good luck.
Can you change the gpu. I prefer a gtx750 ti or 950.
TY
https://linustechtips.com/topic/524210-rm3000-plan-build/#findComment-6959654
TY
Why? It's better than both.
https://linustechtips.com/topic/524210-rm3000-plan-build/#findComment-6959657
No cause i think its hard to find especially in Kuching where its still a small town.
Then a 950 would be fine as well.
https://linustechtips.com/topic/524210-rm3000-plan-build/#findComment-6959692
Though i was thinking of change the cpu to i3 4170 mobo to h97 pro gamer
Lots of games like four cores. You'd be better off getting a four core CPU rather a two core.
https://linustechtips.com/topic/524210-rm3000-plan-build/#findComment-6959713
Nah im just using it to play games like d2 n csgo.BTW does the case come with fans for cooling?
It should.
https://linustechtips.com/topic/524210-rm3000-plan-build/#findComment-6959742
