Arma 3 crash help
Go to solution Solved by Marinatall_Ironside,
i do, its something graphics card related thats the problem
Then try using your old GPU.
I get this Crash message : 0xC0000005. I recently got a EVGA GTX 970 and it has only been doing it since.
CPU Ryzen 5 3600 | Motherboard MSI B550 | RAM 32 GB Corsair Vengance Pro | GPU EVGA GTX 980ti | Case Corsair 4000X | Storage Seagate Barracuda 2TB HDD,  Team GX2 1TB SSD | PSU Sentey 850w 80+ Bronze | Cooling AMD Wraith RGB | PCPartPicker URL https://pcpartpicker.com/list/RN7kGc |
https://linustechtips.com/topic/524184-arma-3-crash-help/
I find that arma doesn't like any kinds of overclocks on the gpu. Is the evga card an SC or SSC varriant?
standard edition, no oc
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6959339
-deleted-
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6959352
Are your drivers up to date?
yes
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6959357
That's a strange issue that I've never encountered. Is the game up to date?
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6959419
i'm pretty sure, i have it set to automatically update
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6963673
Well you might want to manually update the game. Sometimes games don't automatically apply updates as expected. It happens, just not as often.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6966135
yeah it just updated today, it ONLY crashes in multiplayer, it DOESNT crash in singleplayer
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6975803
Did you try to reinstall ARMA 3? If not I suggest you try and reinstall it.
I'll try it out.
Edited by JurunceNK
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6975837
okay, all i did was verified the integrity of game cash
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6975857
Disable any mods with the Corrupt symbol on them.
https://gyazo.com/ae349000faa012327dc578fbc214180a
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6976217
i run it without mods and it still crashes
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6983309
Update drivers, re install the game, and verify the launcher options are all default.
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6983959
i re-installed the game, and updated my graphics drivers. by launcher options do you mean on the Arma 3 launcher or in steam
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984655
The ARMA 3 launcher, not the Steam launcher.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984677
The games is trying to access a chunk of RAM that it does not have ownership of. I highly doubt that there is anything you can do about since its most likely a that a developer has a memory leak from a pointer that was never properly cleaned up.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984688
yes the launcher options are default
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984690
it worked perfectly with my old graphics card so im sure it is a GPU problem not a RAM problem.
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984698
Do you have your old GPU? If so try to run ARMA 3 and see if it is in fact the GPU that's causing the problem.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984763
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984804
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984810
I did and it worked. should i put my settings on the lowest possible with the 970 and see if it makes a difference?
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6984874
0x00000001 - UNABLE_TO_INIT_DXGI is what i have been getting now.
https://linustechtips.com/topic/524184-arma-3-crash-help/#findComment-6985025
