so, i want to build a pc and i need help figuring out what graphics card do i need, i do a bit o gaming, cs:go, minecraft and other games, i would like to understand what all those numbers mean
Do it yourself:
Step 1) Choose your side, AMD or NVIDIA
Step 2) Pick a budget. $180 to $390
Step 3) Choose the highest tier card at the lowest cost while still using a non-reference cooler (So it's not a blower style). Cost being the budget you chose.
Step 4) You're done.
Do it with us: (Recommended)
Step 1) Pick a budget.
Step 2) Tell us your budget and your use case scenario.
Step 3) Receive replies and discussion.
Do it yourself:
thank you,
thank you,
Dont shop by.brand but by model. That way you get the best for your money
