I'm looking to build a new PC and I am having some trouble deciding on some components.
This is my current list:
Case - NZXT Noctis 450
PSU - Antec True Power 750W 80+ Gold
Mobo - MSI Z170A Gaming Pro
CPU - Intel Core i7 6700K
CPU Cooler - Corsair H80i GT
RAM - 8GB DDR4 2400Mhz (2x4GB)
GPU - MSI GTX 970 Gaming 4GB
Storage - 128GB SSD + 1TB HDD
Components such as the Case, PSU, RAM and Storage I am happy with however if any of you think I should upgrade or even downgrade I am more than happy to hear.
However, Im stuck when it comes to the Mobo, CPU and GPU.
I am considering the following changes:
MSI Z170 Gaming Pro >>> MSI Z170 Gaming M7
Intel Core i7 6700K >>> Intel Core i7 6700
MSI GTX 970 Gaming 4GB >>> MSI R9 390 Gaming 8GB
I dont want to bottleneck my build in any way but at the same time want to future proof it as much as possible.
If any one can help and give me some advice on some upgrades or downgrades, It'd be much appreciated.
I will be using it for Music Production, Multi-Tasking and Gaming at 1080p with Ultra settings at 60FPS or higher.
https://linustechtips.com/topic/523801-help-with-custom-pc/
http://pcpartpicker.com/ Please use that website to make lists. What's the budget, what country are you located in, do you need peripherals, a monitor and the OS? Also, welcome to the forums :D Please remember to follow your own threads.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954799
What is your budget?
My Work in Progress PC http://linustechtips.com/main/topic/522048-xeon-build/ <-- That PC was built but never booted:(
My Work in Progress PC 2.0 https://linustechtips.com/main/topic/540583-xeon-build-20-code-name-xenox (Hopefully this one boots.)
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954832
Thanks!
Im in South Africa, just need the build.
Budget is R20 000.00 ($1400.00)
I suggest getting the i5 6600K and upgrading the GPU to something like the 980 or 390X. Also the R9 390 does outperform the 970.
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954858
Thanks!
Keep CPU as 6700k
Whichever Z170 motherboard is cheaper, go for that
390 > 970
Get a 250GB SSD, 120GB fills up too fast nowadays.
USEFUL LINKS:
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954874
How much can the i5 6600K handle as the music production software requires a lot of CPU? Thats why I'd rather drop to the non-K version of the i7 unless they perform the same.
I also saw many videos and posts on the 390 out performing the 970 by ~5FPS but I am an Nvidia fan and dont want to move over if its not more than a minor increase.
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954890
so it depends on what your using it for. if your just gaming i would go with an i5 6600k and a r9 390. if your also recording and editing i would indeed go with an i7 and probably a 970 even tho im not a fan of nvidia
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954916
Keep CPU as 6700k
390 > 970
Is there more to the 390 than just a ~5FPS when compared to the 970 as thats all I've seen?
As well as Im planning on getting another GPU in the future, so will the results be the same when having 2x970s in SLI and 2x390s in Crossfire or is SLI better than Crossfire? (Visa Versa)
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954928
You may want to stick with the i7 6700K because multi-threading can be useful with music production. If you can get the K version you should because overclocking it can really speed things up.
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954930
The 390 has double the VRAM which'll be helpful as more and more games are pushing more than 4GB and crossfire tends to scale better than SLI.
USEFUL LINKS:
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954935
390 has freesync which is just better than gsync in every way. 970 has shadowplay which is better than the amd alternative
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954937
Ok cool, and what can I expect the lifespan to be if I overclock the CPU?
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954948
As long as the CPU is not overheating the lifespan will not really be impacted. Also you have an AiO cooler so you should be able to get a good overclock out of it.
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954974
Ok so what is a comfortable heat for the CPU to be at as well as temps for the GPU as well?
Do you think the Noctis 450 is also a good choice regarding its default cooling?
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6954987
So AMD has the better dual solution?
you mean crossfire (2 gpu's in one system)?
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6955009
Ye
yeah it has but i meant this:
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6955036
Oh ok now i get it.
you can get them cheaper and there are more essentially
https://linustechtips.com/topic/523801-help-with-custom-pc/#findComment-6955068
