Okay so I'm using an ASTRO A40 with the Mixamp as my headset and a Razer Leviathan as speakers. I would like to be able to use the Optical cable which both of them have support for, but the issue is that I only have one optical input. Does anyone have experience with something like an optical splitter or some other solution for this?
https://linustechtips.com/topic/523688-optical-cable-splitter/
If you just google audio optical splitter there are loads.
There also not splitters in the seance of those jack cables with two outputs, its a repeater. So it gets the input and then just matches it on two out puts.
The Dick of the audio page!
https://linustechtips.com/topic/523688-optical-cable-splitter/#findComment-6954371
