Need help
Go to solution Solved by STRMfrmXMN,
Anything in yellow in my signature.
Are you sure that these PSUs fits?
Just about any of them would fit but if you would like a specific recommendation, it would help to link us to where you're shopping/located.
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/523638-need-help/#findComment-6984723
  • 1 month later...
OK, im new so didnt know it.
im not looking for a specific recommendation
https://linustechtips.com/topic/523638-need-help/#findComment-7323795
