So is cable managing soft tubing a good idea
| CPURyzen 7 3700X & 2xE5-2680 V2 | Motherboard - Gigabyte X470 Gaming 7 Wifi & Dell Poweredge R720 |
| RAM - G SKill Hyper X 32 GB & 320GB ECC DDR3 | GPU - RTX 2080 Super W/ Block GTX 1060 6GB (R720) | Case - Metallic Gear Neo Qube (basically an O11D) | Storage - 2TB NVME + 8TB Unraid | PSU - Corsair RM650X Gold | Display - Samsung CHG90 49" | Cooling - Hardline EK CPU and GPU with 3x120 Rad | Operating System - Windows 10 Pro (PC) & Unraid (R720) |
https://linustechtips.com/topic/523323-cable-managed-soft-tubing/
Sure why not, I've seen it done in a few builds. Just make sure that when the side panel is closed, there is nothing pressing against it.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
I don't understand?
I think he means routing soft tubing through cable management grommets and behind the motherboard tray.
Yes I have a c70 and wanted to start a custom build but don't want tubes running over ram and some other parts so it was just an idea
In that case, it would depend on the case. It's probably better to just rearrange the runs so you don't need to route them.
Do you think it would look good? I will eventually get hard-line if I even decide not to aio my CPU and GPU
Is this for look's sake? Or in fear of it leaking or something?
For ease of seeing other components
I don't think it would look good unless it is done very well. Generally, clean runs look better than trying to hide it.
If you make the tubing slightly longer than needed and use angled fittings, you can get plenty of clearance over RAM and other components.
yeah just dont pinch or kink the tubing and youre good
As others have said it's not a problem running it behind the motherboard if you have enough room, but just as an alternative you can get what are called cross flow rads where there are ports on both sides allowing for tubing to not go over or block the view of components, they perform the same as regular rads:
The only thing I'm wondering is where to put the res and pump the r9 390 is enormous
What case you have usually most have a fair bit of space near the front where you can either mount it on the side of the motherboard tray or onto the front rad itself is mounting locations are limited.
