is it a new Computer?
can you post pictures?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/523252-no-sound-only-static/#findComment-6948781
Not a new computer, but not old either
and pictures of what?
where are you plugging your speakers in
can you try different speakers or headphones?
has it happened before? did you just get this pc or is it the first time you plug in audio devices?
https://linustechtips.com/topic/523252-no-sound-only-static/#findComment-6948864
I'm plugging the speakers in the front panel and the back and neither work, i've tried other speakers and headphones. USB headphones work so it's the audio ports or something like that
This has never happened before
https://linustechtips.com/topic/523252-no-sound-only-static/#findComment-6948880
just to make sure... the color of the port you're trying to plug it in is Green, right?
I'm all out of ideas.. your onboard audio is dead
https://linustechtips.com/topic/523252-no-sound-only-static/#findComment-6948922
Yeah it's green, i was pretty sure it was dead but i thought i'd ask
Thank you though
A sound card would help right?
https://linustechtips.com/topic/523252-no-sound-only-static/#findComment-6951027
Thank you though
yes or you could use displayport or hdmi for audio
https://linustechtips.com/topic/523252-no-sound-only-static/#findComment-6953439
