If you get a new GPU and some other peripherals and while gaming your system just shuts down completely/restarts does that mean the PSU can't keep up? CPU and GPU temps are great, I have programs monitoring them both. Also had Frapps, Firefox, Mumble, Raptr, and AI Suite 3 open on desktop.
Corsair AX760 on Hybrid
Fury Strix
ROG Max Hero 7
Razer RGB Firefly mouse pad
Razer Kraken chroma headset
stock Intel heatsink
All settings I establish are reset every time it shuts down. In game setting in World of Warcraft, Mumble headset info, GPU Tweak OC profile, etc.
https://linustechtips.com/topic/522770-psu-not-strong-enough/
The symptom of complete shutdown seems like a PSU issue. Your i7-4790K is quite heavily OC'ed from what I can tell, are your GPU's overclocked at all? If so, reset their OC's and try gaming again. @anthonyc813
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/522770-psu-not-strong-enough/#findComment-6942521
my bad. sig is wrong. CPU is at 4.4 since 2nd to last PC issue was the rad/paste.
a girl I know that does IT work says could be my RAM. I have a 2133 kit but MemTweak is showing 800 per stick..
https://linustechtips.com/topic/522770-psu-not-strong-enough/#findComment-6942548
even refreshing this page is taking forever... what could it be?
it shut off again and all settings in game reset again
https://linustechtips.com/topic/522770-psu-not-strong-enough/#findComment-6942698
Try re-seating your RAM. Take out your RAM, and put them back in, perhaps in different slots.
https://linustechtips.com/topic/522770-psu-not-strong-enough/#findComment-6942718
