Gigabyte GTX 770 2BG - Overclocking and Power limit - Confused
Slomka
Hi guys.
A few days ago I decided to crank up my 770.
Unfortunately I was able to just get 30 MHz up on Core and 150 MHz on Memory.
On Valley benchmark I got best score of 2757 min: 32.4 FPS max: 124 FPS
But on stock I got 2700 with 30 and 122 FPS respectively.
So the performance difference is very small.
I moved my power limit to 110%, but I noticed that in MSI Afterburner the power on the chart doesn't exceed 80%.
Do you know what could be causing that? Is this the reason I can't get any significant overclock and performance boost?
Your overclock is mostly limited by voltage, did you try bumping it up a bit?
The only two reasons i can think of that would prevent your card from going over 80% power limit is thermal throttling or low gpu usage ( cpu bottleneck ). The later is highly unlikely in Valley, What kind of temps are you getting?
Also, in GPU-Z you can see the reason your card is being held back, its the Perf cap reason in the monitoring tab
CPU: Intel Core i7-4790k @ 4.8ghz  Motherboard: Gigabyte G1.SNIPER 5 Memory: G.Skill Ripjaws X Series 32GB (4 x 8GB) DDR3-1600 Storage: Kingston V300 Series 240GB Storage: Western Digital Red Pro 3TB Video Card: 2x(SLI) Asus GeForce GTX 780 3GB DirectCU II @ 1410mhz / 1600mhz Case: Corsair 760T White Power Supply:  AX1200i  Buildlog: [ Build Log ] Black and Green build
Hi guys.
it's normal... i have my gtx 670 power limit to 100 and it never goes to 85+
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
CPU bottleneck is impossible. I'm running on i7-6700K.
I didn't mess with voltage on core.
I get temps up to 80 Celcius.
This is what I got by the end of the benchmark.
http://imgur.com/k6nyniy
Seems like the GPU is working on max and just doesn't need all the power it can get wrom PSU am I right?
So if I increase the voltage and clock speed it will be able to use more power?
Vrel and VOp are from what I see realiability voltage and operating voltage and these seem to limit my GPU.
You are correct on all three points! Your gpu simply doesnt need to use more power! You will see an increase in power consumption and maximum stable clock speed if you increase the voltage and Vrel and Vop are reliability voltage and max operating voltage limitation.
Thanks for the answer.
However my stock voltage is 1.2V which from what I've read is pretty high already and on most forums i saw that people didn't recomend to go higher than 1.2V.
I've heard of guys going to 1.3v on a GTX 770, but depending on which version you have you may not want to. You could be running pretty high temps, especially on the VRMs
4790k 4.9GHz @ 1.375v, HD 7970, 850 EVO SSD's, Corsair 750D Airflow Edition, SeaSonic 860w Platinum.
You cant go over 1.212v on stock bios. Everything you can do in stock bios is pretty much 100% safe for 24/7 use if your temps are ok!i used 1.35v daily on my GTX 780 for a long while, except i was watercooling.
So I guess I'll try to mess with my voltage and see if it does anything. I wonder what will happen if I just increase voltage. Guess there is one way to find out. :)
If I don't get any significant performance boost I'll just return to my stock values.
Update:
I tried increasing the voltage on my GPU by the maximum amount that MSI Afterburner allows which is 12mV, but when I do it, apply and run benchmark the voltage I see on GPU-Z doesn't exceed 1.2V. Any ideas why?
Update 2: I've done some research on the internet and some people say that WindForce (which is my GPU - Gigabyte GTX 770 2BG Windforce) has locked voltage. Could it be true? Then I would have to change bios on my gpu right? If yes then I will quit messing with this. This is my gpu http://www.gigabyte.com/products/product-page.aspx?pid=4629#ov
Update:
When they say locked voltage, they mean you have a limit over voltage control. you CAN control it, but really not much, using a custom bios, you could push as much voltage as your balls allow you to!
