Weird CPU clock issues
Solved by SkilledRebuilds,
Sometimes...
Even if the CPU temps are fine, if the socket temp goes above a certain temp (can be different on other boards) it will throttle on some boards.
Adding a fan pointed at the socket (or on the back behind the board) and even a fan at the VRM's as they can induce throttling on some boards even before the CPU gets too hot.
How hot does the heatsink under the CPU get? (Dont just outright touch it, it could be hotter than you think)
If it seems way too hot for your liking, throw a fan pointed at it and retest your situation.
I've been looking at newegg user reviews and other sources and some say the vrm heatsinks can get quite warm with some configs.
