I´ m planning to make watercool my rig but I don´t know what amount of radiators and sizes of it should I buy? I´ve got Phanteks Enthoo Evolv ATX, 6700k, and 980 ti. I was thinking about 360 on top and front. I´m planning to overclock GPU and CPU as well (maybe mosfet of my Asus Maximus VIII Hero). I was thinking about EK SE 360 with Corsair SP120. Is good to go with one pump (EK D5)? Is my plan good or not?
Thanks.
https://linustechtips.com/topic/521032-radiators-help/
Thanks.
One D5 will be plenty, 2x 360mm rads will be a good start probably enough to keep fans at medium speed. I wouldn't recommend SP fans however, I really dislike mine.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/521032-radiators-help/#findComment-6920859
