Fan Xpert 2 on P9Z77-V Pro How To?
Solved by Leonard,
Firstly, i think you mean P8Z77-V PRO and not P9.
Secondly, this MOBO and drivers for windows8 are compatible with windows10 and has the same functionality as on windows7.
Thirdly, this MOBO's fan xpert version is version2 and not version 1.
Fourthly, yes you do need to run the Fan Auto Tuning in order for the utility to be able to control the fans and after which you can set up different fan curves as you see fit or keep the original or keep the original or make your own.
