Here are the parts that I have ordered: http://pcpartpicker.com/p/JNVyGX
I am not planning on overclocking for around 6 months at which time I am going to buy a different cpu cooler and one or two more case fans.
My question is if I am going to be good going with the stock cpu cooler and the two fans that the Fractal Design Define R4 w/Window comes with? Thanks!
https://linustechtips.com/topic/520590-need-help-with-cooling/
Yes, the cooler is just a bit louder than I like, so I turn down the PWM fans on my cooler, other than that it isn't that bad
https://linustechtips.com/topic/520590-need-help-with-cooling/#findComment-6914433
