Peltiers + water cooling
Solved by W-L,
I think I found out why:
"The TEC must have a maximum heat transfer capability about 2 - 3 times more than the amount of heat that the CPU puts out."
So for my 144W CPU, so would I need a 450W Peltier. At 12V, so is that 15A.
Thats a lot of power, just for stock CPU speed.
ot to mention, that you need 3 times the radiator space as well.
That's true but there is also a threshold where they are effective if you run the a full power they tend to get too hot even on the cold side since the ability for heat to wick out of the peliter is limited by heat transfer between it and a waterblock or large air cooler.
