I think it's done. My planned build for editing/gaming and 3d rendering. My build that I will use in my day to day life. It's not a top of the line 5th gen i7 with a gtx titan, or some low end pentium with a 730. It's not the best, not the worst, but it will do for the things I do :3
http://pcpartpicker.com/user/GroundHound101/saved/#view=nnJLrH
*If you have any suggestions that you think will benefit me, comment below. If not, then, well, i don't know c:
If you play Geometry Dash, would you take the time to rate this demon? 14986973 ;3;
https://linustechtips.com/topic/520372-finalizing-shadow-blade/
Might wanna start here, the 1231v3 is a good deal better value than that CPU overall, and at that budget you could easily go X99
PCPartPicker part list: http://pcpartpicker.com/p/cpzT23
Price breakdown by merchant: http://pcpartpicker.com/p/cpzT23/by_merchant/
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($232.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($62.98 @ Newegg)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($32.99 @ Adorama)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive  ($122.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($298.99 @ SuperBiiz)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Rosewill Hive 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.89 @ OutletPC)
Total: $900.80
Generated by PCPartPicker 2016-01-04 15:27 EST-0500
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6912450
Total: $900.80
x99 apparently has a terrible memory imc unless you spend time tweaking it. And i'm not too sure about the Xeon tbh
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6912489
memory imc?
the Xeon is exactly the same CPU as the i7, just with lower clock speeds, any intel i5 or above running above 3ghz is going to be more than enough for gaming
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6913600
memory imc?
A. I do somewhat plan to OC in the future, so not sure about Xeons. B. i5 is locked at 4 threads. I'm a heavy multi tasker, which won't help that situation
*typo, meant imc, not memory imc c:
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6913707
Spending Extra money to OC really isn't worth it anymore, unless you have like a 144hz display.
here's an idea for the X99 build, still not sure what you mean by imc though
also the 390 is a fair better choice compared to the 970, partly due to potentially better DX12/Vulkan support, and becuase it has more performance overall, but mostly you save money on a free-sync display vs a G-sync display
Included a free-sync display, you could always add a secondary display later, though a 1440p display as your second display is going to be a lot better
PCPartPicker part list: http://pcpartpicker.com/p/MVs3rH
Price breakdown by merchant: http://pcpartpicker.com/p/MVs3rH/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($374.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Amazon)
Motherboard: Asus X99-A/USB 3.1 ATX LGA2011-3 Motherboard  ($249.99 @ Amazon)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($69.99 @ Adorama)
Storage: Sandisk Ultra II 480GB 2.5" Solid State Drive  ($133.99 @ Amazon)
Storage: Western Digital Blue 2TB 3.5" 5400RPM Internal Hard Drive  ($77.89 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($308.99 @ SuperBiiz)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($38.98 @ Newegg)
Power Supply: Rosewill 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.89 @ OutletPC)
Monitor: LG 29UM67 60Hz 29.0" Monitor  ($299.99 @ Micro Center)
Total: $1674.69
Generated by PCPartPicker 2016-01-04 18:09 EST-0500
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6913819
Total: $1674.69
I need ShadowPlay, hence the 970. I have two monitors for multi tasking.
*imc= Integrated-memory-controller
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6914040
AMD has GPU accelerated streaming/recording with raptr, otherwise you could use DXtory/OBS to do the same job, is it really worth losing performance and future support overall just for shadowplay?
well what's wrong with it's memory controller? google is telling me nothing, if it's related to RAM speed, RAM speed doesn't matter for anything aside from iGPUs for the most part
https://linustechtips.com/topic/520372-finalizing-shadow-blade/#findComment-6914407
